Does Telus / Public Mobile support the Twitter short code 21212?
vanhalen26
It worked when I was with Rogers but I ported over and it stopped.
9 REPLIES 9
SIM-phony
If you want an official response, you'd have to contact the Moderator Team, or other actual staff.
How do I contact the Community Moderators?
When will they get back to you?:
  • Support hours are in EDT and run Mon-Fri 9AM to 9PM, and Sat-Sun from 9AM to 7:30PM. Outside of these hours they will not be responding to private messages, and will be queued for the next day. So don't worry, they will get to you.
  • Messages are responded to in the order in which they are received, which can affect response time depending on queue length.
  • Usual response time varies between 1-3 hours, but can take up to 48 hours.
  • Please do not send multiple separate private messages, as it slows down support.
vanhalen26
Anyone know how I get a reply from Telus / Public Mobile?  Maybe it’s an oversight they can easily correct.
SIM-phony
Public has said in the past that they support Twitter's 21212 and 40404 short-codes in this thread from 2015, but that either has changed or broken based on what others have said in this thread. I personally have used none so they may work.
LEGO
I found this web page, seems like it is Public Mobile, but... I think it is old Public Mobile Community before Telus purchased it OR before Public Mobile Community moved to a new network platform.
vanhalen26
Thanks - too technical for me and 100 probably not enough.  Anyway to ask Telus to implement? Seems most carriers do.  Not sure why they wouldn’t.
LEGO
@vanhalen26 There is a workaround posted by @Cheetah24: click here
vanhalen26
Oh, that’s unfortunate.  I picked up some good information in real time that way from some twitter accounts I follow.  How do I request that this gets added?
LEGO
@vanhalen26 No support for Twitter short code 21212 nor 40404
passiveegg
Yes they do, you are able to short code with Telus as well.
Use this link for reference:
https://help.twitter.com/en/using-twitter/create-twitter-account-mobile
