06-29-2023 09:44 PM - edited 06-29-2023 09:53 PM
I'm on the legacy rewards system. If I go to the "My Rewards" page, will it show me my rewards there and will it automatically convert me to the new points system (which I definitely do not want)? It seems PM is always trying to trick people into switching over to the points system! Seems ridiculous to have a separate page for rewards anyway, don't see why can't it all be together! SMH! Thanks.
06-29-2023 09:46 PM
@KeikoAB no worry, it won't
you can click on the My Reward page and it will show you the current rewards you hvae. So, if you are on legacy, it will show you your legacy rewards you have and it will see them all in $ values
06-29-2023 09:46 PM
No, you need to manually go through the steps to switch. Don't.
