02-27-2020 12:33 AM - edited 01-05-2022 09:40 AM
I'm currently using 2 phones right now.
One is with my old carrier (Telus Prepaid) and the other is with Public Mobile.
For simplicity, I will refer to them as the Telus phone and Public Mobile phone.
I have already successfully activated and tested the Public Mobile service.
(everything is working properly)
Now I want to port my Telus Prepaid number over to Public Mobile.
My Telus Prepaid account is still active and I have the required information for porting.
But I was wondering, should I turn off any of these phones before doing the number porting process?
03-07-2020 02:47 PM
When we ported our number we left both phones on. Within a couple of minutes the porting of the number was completed and we were able to use the phone.
02-27-2020 10:41 AM - edited 02-27-2020 10:42 AM
@andy123 wrote:I'm currently using 2 phones right now.
Welcome to PM
As everyone has already mentioned, you don't need to turn off the phones.
once you fill out all the porting information. The other phone number will stop working on the "Telus phone".
It should only take a few seconds if not minutes for the port to be switched over if everything is entered correctly at the porting screen
Porting Tips:
Cheers
02-27-2020 10:30 AM
@andy123 Keeping both phones on is ideal. Once your Telus phone stops working it means that the port is 100% done.
02-27-2020 06:50 AM
Usually no but once it's ported doesn't hurt to try. Just to restart and refresh your phone. They message you when it's complete
02-27-2020 06:11 AM - edited 02-27-2020 06:15 AM
@Wiggly wrote:It is not necessary to turn off any of your phones. I did reset my network settings once I ported my number over just to ensure everything updated properly. Congrats on the move.
Occasionally, a device restart is needed before everything works.
02-27-2020 05:57 AM
02-27-2020 12:56 AM - edited 02-27-2020 12:57 AM
No need to turn off any phone. It is even better to turn them on. You will receive SMS from Telus about porting process.
@andy123 wrote:But I was wondering, should I turn off any of these phones before doing the number porting process?
02-27-2020 12:55 AM
Porting happens fast from Telus prepaid to Publicmobile. Publicmobile plans let u enable data at
A reasonable cost. Let smartphones be Smart. Welcome to a better place.
02-27-2020 12:45 AM
@AE_Collector wrote:No, just let the porting process do it's thing. No issues.
i ported my wife's TELUS prepaid to PM a yearborcsonagonand it took less than 1 minute to be 100% done... ready to go.
AE_Collector
Me too....Telus to PM in less than a minute. Provide as much info as possible. Porting will close your Telus account.
02-27-2020 12:38 AM
It doesn't matter. Your sim cards don't even need to be in phones during the porting process.
02-27-2020 12:38 AM - edited 02-27-2020 10:46 AM
I ported my wife's TELUS prepaid to PM a year or so ago and it took less than 1 minute to be 100% done... ready to go.
AE_Collector
