3 weeks ago
Hi everyone,
I have a Samsung Galaxy S10e, which supports 4G LTE. I’m currently on a 3G speed plan, but I’m planning to upgrade to a 4G speed plan.
Do I need to replace my SIM card when I switch plans?
My SIM card was purchased in October 2022.
Thanks in advance for your help! 😊
3 weeks ago
Hello.
As mentioned, all you need to do is swap the sim card from your old phone to new phone. Speaking of new phone, here is the volte checker to make sure your new phone will work on the network. Just enter your imei number
3 weeks ago
@Spyg1rl
You can just upgrade your plan, no need to change SIM.
3 weeks ago
No, your current sim will work for any plan
Just upgrade the plan as you like, remember to use Change on Renewal option to schedule the plan change on next renewal
