05-11-2023 11:48 AM
I ordered a phone but never got tracking number just order number. Phone was ordered on Apr 29
05-11-2023 12:01 PM
@brianshort_31 I believe the tracking email is a hit or miss. So, it is best to open ticket with support and confirm if they have shipped out the order yet:
1. Please open ticket via Chatbot (requires access to My Account) using direct link: https://publicmobile.ca/chatbot.
Start by typing "Contact agent ", then click "Contact Us", then click "Other", click "Click here to submit a ticket ↗""
Next, enter your Community login, then enter your question. Finally use My Account login or 4 digits PIN to validate.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
05-11-2023 11:57 AM
@brianshort_31 wrote:I ordered a phone but never got tracking number just order number. Phone was ordered on Apr 29
For my experience PM had sent tracking number for me after I received the order! According a member of this community's post that you could use UPS (PM will send the order by it) app that using your address to track your order.
05-11-2023 11:51 AM
I'm not sure how they send phones but try that order number on Canada Post. Then maybe the destination postal code. Nor am I sure if this is still a thing. But always worth trying.
05-11-2023 11:51 AM - edited 05-11-2023 12:01 PM
HI @brianshort_31 it is true PM usually don't send the tracking number for phone. But you get an invoice email at least?
for tracking and update, please submit a ticket with CS agent and they can provide you that
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
