06-27-2022 11:15 AM
I have lost my sim card and number is unused since 6 months but money has been deducted from my account every month. I tried to didn't find any solution to deactivate my account as i tried everything.
06-27-2022 01:01 PM
OP lost their SIM card @Yummy , 611 is not an option unless they are swapping the SIM's first. 🙂
@Gagandeep1 Do you know the 4 digit account pin. If you do, then you can use @dust2dust 's method to remove autopay by calling # 1-855-478-2542.
06-27-2022 11:35 AM
@Gagandeep1 If you really decide to leave PM with no 2nd thought, you can call your credit card and do a charge back of the last payment to PM. Once PM sees the charge back, it will suspended your account immediately and you basically have closed the account. But again, only do it if you have no hesitation to close the account. It is trouble if you want to resume this account with this number
06-27-2022 11:24 AM
Without access to your account (if) you could also dial 1-855-4pu-blic to get your next renewal date. The evening before that date, pause your credit card in your credit card account. Leave it paused until noon of that date (the next day) then unpause it. That will suspend the account. You then get 90 days to decide if you want to keep the account. Maybe somebody here would like to take it over with it likely having the old rewards system on it.
Keeping the account is as easy as buying a new sim and changing it in the account.
06-27-2022 11:20 AM
- Disable autopay through self-serving account or dialing 611.
- Remove credit card from your self-serving account.
-- On next renewal your account will be suspended due to no payment and closed after 90 days unless you renew manually.
- PORTing your number to other provider cancels your PM account immediately.
06-27-2022 11:18 AM - edited 06-27-2022 11:18 AM
@Gagandeep1 Yes, because there is no way PM to understand you don't need the service
Do you have access to My Account? If so, login to My Account and disable Autopay and remove the credit card
If you do not have access to My Account, open ticket with PM Support and reset the credentials. Then you can log in and disable Autopay
To reset the login, at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
First type: "Forgot log in information"
Then Click "Contact Us"
Finally Click "Click here to submit a ticket"
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
