Data
MichaelD5991
How do i reset my phone data
7 REPLIES 7
@MichaelD5991
Confirm you are out of data by logging into self service but first clear your cache and then open a new browser window in incognito. Once in self service click on the spinner icon to refresh the data usage.
@MichaelD5991   Your data will reset automatically on your plan renewal date.
If you're out of data, you can go into your account and buy a data add on to tie you over until your plan renewal date.
MichaelD5991
I would like to know how to reset data my data will not work it’s Ben a week
HALIMACS
@MichaelD5991
If you mean you have run out of data, you could either buy a data add-on or renew your plan earlier.
Clau5550
If you have an IPhone and are talking about tracking how much data you have used, you can go into settings, cellular, scroll down to reset statistics. If you do that on the day of your payment it will reset to 0 so you can track how much data you use.
HI @MichaelD5991
you meant PM did not reset your data when a new cycle starts?
try to clear cache, and restart the browser and re-login My Account?
or use Private or Incognito Mod to check My Account
Metal1967
@MichaelD5991 Data counter on your phone? Or did you run out of data?
