4 weeks ago
4 weeks ago
@Sim2023 wrote:My data starts to work slow whenever I'm about to run out. Is that normal?
There is no data slowdown initiated by Public Mobile as data is nearly out. If you're on a plan that includes unlimited data at reduced speeds, speed is reduced to a much lower amount only after of the regular speed data has been used up.
4 weeks ago
Content removed as per instructions by Public Mobile as it isn't appropriate for a customer support agent to be prompting customers for account information in a public message forum
4 weeks ago
Personally I never see that
but if your data runs out a lot, would you consider buying something with more data?
