Data not working after plan change and renewal
BamaMan
Was working fine until renewal and plan change. Can an admin help me.
7 REPLIES 7
@Scottyho wrote:
Yes I'm in Edmonton, hopefully it's just a network issue
Telus Cable theft issue. Hopefully they repair it soon.
https://www.telus.com/en/qc/outages
Scottyho
@Scottyho There are some active Telus outages in Edmonton and Calgary area. Are you from Alberta?
Scottyho
Didn't work for me, I even pulled the sim
NDesai
@BamaMan Try turning Airplane mode on/off. When you turn on data and turn off wifi, does it show signal and connection to 5G. LTE or LTE+?
Scottyho
I have the same problem
hairbag1
@BamaMan
try rebooting your cellphone first off.
