Data almost used up in 4 days
Caper862
I received a message from public mobile this morning stating I used 15G out of my 20G of data which renewed on may 16. It has been less then 4 days since my data renewed and I can't see how I used 15 G in that amount of time since I didn't do anything different. Please Help Me Wayne
Caper862
I figured out the issue. My data renewed on may 16th but my public mobile account says it renewed on may 4th. It didn't renew on may 4th it renewed on may 16th.
@Caper862
Best to login to your account on the PM app or the website and check on the correct amount of data usage and also the history of your usage.
It notice could be your phone data counter which needs to be cleared every 30 days.
hi @Caper862
most the time, PM tracks usage without problem
check your phone usage and see if any app downloaded a lot
and use Incognito/private/secret mode on the browser to login My Account to confirm if it shows you used 15GB , and check usage history
if in doubt still, ask PM.
 submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can submit  ticket by direct message:
