09-01-2021 08:16 PM - edited 01-06-2022 03:20 AM
I've deactivated the old credit card which is currently bonded to the phone for automatic payment. I tried to log in to the self-serve section but seem to have forgotten the email and password for the account, I've attempted multiple emails for "Forgot Your Password" but none of them seem to work. May a staff member provide some assistance?
09-01-2021 08:44 PM
Maybe it's the same e-mail address you use for your Community account.
Click on your avatar on upper right of screen, go down to My Settings, there you'll see your Community e-mail address - try that one.
09-01-2021 08:20 PM
Explain your issue to Contact Customer Support Agent by CS_Agent ,
they can solve your issue, they are nice Service Team they will help you 100%.
Here’s How To Contact Customer Support Agent by CS_Agent, and Submit a Ticket
Good Luck....
09-01-2021 08:19 PM - edited 09-01-2021 08:20 PM
@zhong1 if you are unable to "crack" your own account using Forgot Password, then you have to open a ticket with PM Customer Support and they can sort it out for you
(even you are able to find the correct email, your next obstacle would be to answer your own Security Question.. )
1. For faster response (2 to 48 hours), Click on the bubble in the lower right corner and request Cusstomer Support Agent assistance, or you can also use this direct link instead https://publicmobile.ca/chatbot. Start with typing "Submit a ticket", click on "Contact Us", click on "Other" from the choices, click "Click here to submit a ticket" then Follow the prompts to submit a ticket.
2. Or you can Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
(After you open a ticket with Customer Support Agent, please monitor your Community inbox, envelope on the top right. Customer Support Agent will communicate with you via messaging within Community)
