10-25-2017 04:36 PM - edited 01-04-2022 02:48 PM
Going to change to a new plan $141 starting november but I cant look up how much data is going include in it?
10-25-2017 05:24 PM
Yup my 6GB 90days plan isnt enough and I wasnt sure what I changed to will has more data or not. 12gb 90days would be good for now.
10-25-2017 05:18 PM - edited 10-25-2017 05:18 PM
@wetcoaster wrote:
@NDesai wrote:
@sangusk wrote:Ok thanks everyone. I found that I can see the detail for my future plan only if I click change my plan.
What plan did you futuredate? Perhaps the current offering might give you better choices?
Looks to me like it was the $45 for 4GB LTE promo. But I might be wrong...
Edti: @sangusk's picture, posted a couple of seconds before my reply, seems to confirm it. 😉
Yup, it is. OP You have the promo deal that is no longer offered. If anything goes wrong on your renewal, contact the moderator.
10-25-2017 05:14 PM - edited 10-25-2017 05:16 PM
10-25-2017 05:14 PM
I got this for $141 90days
10-25-2017 05:09 PM - edited 10-25-2017 05:09 PM
10-25-2017 04:59 PM - edited 10-25-2017 05:01 PM
10-25-2017 04:56 PM
@sangusk wrote:Going to change to a new plan $141 starting november but I cant look up how much data is going include in it?
My guess is, you've future dated a plan change to a plan that is no longer a current offering. You will still be able to get the plan, assuming the plan change works as scheduled. If you want to see the details, here's a handy chart that listed the plans before and after the changes in September:
10-25-2017 04:54 PM
Not too clear on what you mean. 🙂
Do you mean that when you go to the Self Serve site and login that you don't see your plan? Or that you see your old/current plan because you've just future-dated a new one and that's where you can't see your data?
If it's the latter then you should be able to send a private message to a moderator with your email address and phone number and they should be able to tell you. 🙂
10-25-2017 04:54 PM
Should show under Main Screen - OverView - My Plan - Plan details
If not able to see feel free to msg a MOD, they are great and always able to help
10-25-2017 04:53 PM
You should be able to see how much data is included on the plan you want since you have to select the amount of data you want.
