01-26-2024 09:56 PM
Hi ,i am a new subscriber ,and i do i keep my existing phone number ?
01-26-2024 10:18 PM
@mgodin - Also there is a way to see if your phone number is able to be ported to Public Mobile. (Ignore that it is Koodo, all of the Telus Family uses this phone number port tool.) https://secure.koodomobile.com/checktransfereligibilityparrot/default.do
01-26-2024 09:58 PM
@mgodin : Yes you can keep your existing phone number generally, but you will need to port your old number from your previous provider to public mobile. For more instructions please refer to, https://www.publicmobile.ca/en/bc/get-help/articles/transfer-your-number
01-26-2024 09:57 PM
If you port it in from your old service provider, then you’ll be able to keep your current phone number instead of having to get a new one.
