Changing from $27 a month plan to 40 a month plan immediately
larr99
I have a legacy account that bills every 90 days for the $27.00 plan.  It was just renewed for three(3) more months, but I want to upgrade/change my plan to the $40 monthly so I can call USA numbers.  If I change plans immediately, will I lose the payment I just made, or will I get a credit back ?
Thanks for your help
@BKNS27 wrote:
@larr99
Please also note that once you upgrade your plan. You won’t be able to downgrade to your old plan or a lower priced plan.
There isn't any way to know that for sure.  There's no such rule that forbids downgrading to lower priced plans.
@larr99
hairbag1
@larr99
If you just wanna make calls to USA from Canada… you can log in to your account >. Rewards > Catalgue and you can see 1000 US calling mins for 10 Pounts. As ling as you have 10 Points to redeem you can get this add-on for calling USA from Canada. Those 1000 mins will stay in your account until you use ‘em up.
Sansan
You will lose the payment you just made unfortunately.
Best to Change on Renewal.
What phone do you have? Not all phones are approved on PM to make calls to USA due to 3G shutdown there.
