06-24-2022 04:09 PM
I meant to change my daughters phone number and port another number over and we are all with public mobile I accidentally changed mine. Need to retrieve my phone number back. Please contact me asap.
06-24-2022 04:25 PM
HI @Sprai123 , there is a chance, slim chance. Only if the number you just lost was originally from PM. You didn't port that number into PM before. If that was a number ported into PM , there is nothing PM can do as the number would have returned back to the original carrier who assigned you the number
But open ticket with PM CS Agent, and explain and hope they can help
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
06-24-2022 04:21 PM
@Sprai123 @Hi hopefully you can you will need to open a ticket, to speak to a customer service agent Click here or if you are having issues with Simon you can send private message to a CS Agent here: https://bit.ly/2GGCJzH
