08-14-2025
02:56 AM
08-14-2025
05:20 AM
computergeek541
Greetings, I put my account on hold because I'm in the US and I have no network here. I even tried to change my subscription for a Canada-US one but I still wasn't getting network. I want to re-open my account before the 90 days expires but would like to get a cheaper one such as the Canada-wide with 1GB at 20$ per month but it's not available when I go in the section to change my subscription. Could anyone tell me why?
Thank you kindly,
08-14-2025 01:40 PM
Yeah, I've done all that was required but still didn't get network. Thanks!
08-14-2025 01:38 PM
Not very customer friendly of PM not to let clients have access to all options of subscriptions but oh well...Yeah I've been using WhatsApp, it's very helpful. Thanks!
08-14-2025 08:54 AM
You mentioned that even after changing to a Canada-US plan, you were not “getting network”. It should have worked as long as you enabled Data Roaming on your phone. In the US your phone will connect to AT&T, T-Mobile or Verizon. (Roaming is included in the plan.)
08-14-2025 05:20 AM
@BKNS27 wrote:PM has made it impossible to downgrade from your current plan. You will need to login to your account on the PM app or on the website then go to Subscription>Manage Subscription> Change Subscription and it will list all plans you are eligible to switch to.
It's not "impossible" to downgrade to a lower priced plan. While it's true that customers won't have access to all plans, the only thing that we know for sure is that this customer doesn't have the $20 plan available.
08-14-2025 04:27 AM - edited 08-14-2025 04:32 AM
Meanwhile you can use WhatsApp or TextNow app for calling or texting when connected to wifi.
