11-15-2022 06:05 PM
I accepted a change of plan by text . but system did not upgrade my account .
11-15-2022 07:08 PM
@Furrymiker13 Make sure that they understand the error is from PM's system not changing the plan as scheduled and promised by replying to their offer, so you shouldn't be charged again (except for any difference in plan cost, if applicable) when they make the switch.
11-15-2022 07:03 PM
Think I have a ticket open now will wait and see if I get contacted
11-15-2022 06:48 PM
@Furrymiker13 You don't see the plan changed after refreshing the account page with the refresh option bottom right or when using incognito/private mode?
Your options are to login and schedule a plan change now for next renewal or submit a ticket via chatbot ask customer support to switch you over since you had responded to the PM text offer and expected the change to go through.
Here's a link to chatbot: https://www.publicmobile.ca/get-help
11-15-2022 06:37 PM
Hi @Furrymiker13 you used Private or Incognito browser mode to check?
How about payment history, check there and check your credit card to see if PM charged you need or old plan amount
11-15-2022 06:34 PM
3 days since plan updated again and did not change
11-15-2022 06:24 PM
Yeah same experience, I just did it through the self serve instead of the text, a coworker and a cousin had the same issue when just doing it via text
11-15-2022 06:22 PM
I think this was a clever idea that failed. I don't think I've read of people actually getting the plan scheduled by replying or clicking yes. Log in and select it to change at the next renewal.
11-15-2022 06:10 PM
@Furrymiker13 hi were you charged the cost of the new plan? if renewal date just passed use a different browser in secret or incognito mode , sign back in to see if account updates
11-15-2022 06:09 PM
@Furrymiker13 When is your renewal date as replying YES would schedule plan change to the next payment date.
Or if your account just renewed, then login using incognito/private mode as PM has caching issues with the self serve since the recent account update.
