Change my name of PB community
Son73
Is it possible to change my name, which appears on the PB community?
1 ACCEPTED SOLUTION
Accepted Solutions
0PX9O4
@Son73
Yes it is! You can contact CS Agent for this.
9 REPLIES 9
0PX9O4
@Son73
Dunkman
@Son73
You use to be able to change your username for the community by yourself.  Click on your community avatar on the upper right corner of website.  Click on settings.   Choose change username.
Edit:  Looks like that option may not be available anymore.  Contact CSA as described above.
Son73
I've clicked on the setting. However, I did not find the username change option.
z10user4
 @Dunkman : Um...so...like...did you test your statement? There's no change username option. Maybe there was but it would seem you didn't check before replying if there still is.
No, there is no option to change user name by the owner, or I cannot find it...
@z10user4
There is the option under my settings.  Maybe oracle setting.  Looks like not available for rest of community members.
@Dunkman   no, we don't have option to change username... just like we don't have option to change Avatar to any pictures we want 🙂
@Dunkman wrote:
@z10user4
Yes, the setting has always existed (and still does) but it's not accessible to the mass userbase.
Since you've just opened this account, I would suggest simply opening a new Community account. Before you do that, remember to remove your e-mail address from this current account so that you can link it to your new Community account for Community reward purposes.
