Change my email
kathwal56
 my email address does not exist how do I change my email address i have no access to my email
1 ACCEPTED SOLUTION
Accepted Solutions
z10user4
 @kathwal56 : You can still log in. It just acts as a username login id here. If you've forgotten your password then yeah that's a problem. But you would really want to get it changed.
To change the e-mail address associated with your self serve account, load up https://widget.telus.tiia.ai/publicmobile/publicmobile.html and then type "change self serve email address".
z10user4
Contact customer support where you will have to verify your account via Simple--Simon when you submit your ticket. Once a CSA contacts you.... you will have to answer correctly 3 out 4 questions about your account to further verify you are the account holder. Then you will be able to change your email. Make sure you then match your community accounts email to your self serve account.
@kathwal56
The only way to have your email changed to your Self Serve account is to ask the Customer Support to do it for you.
To contact the Public Mobile Moderator_Team, there are two methods to reach them:
1 -  Faster - as @computergeek541 already posted through SIMbot
OR
2 – Slower - Use this link to:
Private Message to Public Mobile Moderators (PM Customer Service Representatives)
If you mean the email to your Community account, you can do that yourself in My Settings  under your Avatar, top, right of your Community page.
@kathwal56
you need to Contact Customer Support Agent by CS_Agentand Explain your issue to
they can solve your issue, they are nice Service Team they will help you 100%.
and them will change for you,
Here’s How To Contact Customer Support Agent by CS_Agent,
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to CSA,Click Here link,
  • or you can send a private message to Customer Support Agent by CS_Agent, by Click Here link,
  • You’ll need to be logged in to your Community account for the link to work.
  • your account number,
  • your phone number,
  • your account 4 digit pin,
  • Customer Support Agent by CS_Agent, will Response to your inbox by private message
  • During business hours, we strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
    • Monday to Sunday: 6 AM to 10 PM EST
         Good Luck..
