03-16-2022 09:49 PM
Hi,
I purchased a Certified pre-owned phone last week, but after I am using it, the sound was burry and turns very hot in a short period of time. I wanted to create a return ticket online, but I wan not able to do that. Please help me with that.
Thank you so much.
Feng
03-17-2022 01:57 AM
Contact customer support with your order #, email used for your phone order and the shipping address that your phone was shipped to..... customer support will opeh a ticket with the CPO deoartment to contact you and send a prepaid return shipping envelope. The CPO department has different response time mandate then regular customer support so it may take longer then 48 hours to hear from them.
03-16-2022 11:50 PM
unnecessary repetition
03-16-2022 09:58 PM
Thank you so much.
03-16-2022 09:56 PM
@fshen don't use Chatbot to create CPO related ticket, something wrong and the submit button didn't work for that type of ticket, please use direct message to open ticket with PM support:
**Monitor your Community inbox, envelope on the top right, after ticket is opened. CS Agent will reply and work with you via messaging there
03-16-2022 09:53 PM - edited 03-16-2022 09:54 PM
Contact the support agents.
