02-10-2023 02:17 PM
Hello, I just moved over to Public Mobile on 7 Feb 23. I transferred my current number and I missed the SMS text as the messages were slow. What do I need to do to get this fixed?
Many thanks
Judy
02-10-2023 06:39 PM
@foxybw704 wrote:7 Feb 23. I transferred my current number and I missed the SMS text as the messages were slow. What do I need to do to get this fixed? no port
@foxybw704 - check your inbox for the Telus porting phone number, I've sent it to you.
Do you have the old provider's SIM card still?
02-10-2023 06:31 PM
02-10-2023 06:28 PM
I have the same
02-10-2023 03:39 PM
@JudyMac11 Yay !! Happy you got it sorted out and welcome to public mobile
02-10-2023 03:09 PM
It works !!! thank you lovely community. !!!
Much Love from the Maritimes
02-10-2023 02:55 PM
Called the number the wonderful lady on the person did all the porting of phone number, just waiting now to see if it works. fingers crossed !!! Thanks for the help
02-10-2023 02:33 PM
lol @Handy1 @softech @dabr .... @JudyMac11 well you have the Telus Porting number (a few times in your inbox, 🙂 )...
but, if you no longer have the SIM card from the old provider (as it has been a few days now since you activated with Public, you may need to contact them within the 90 min period you have to restart the porting process to get a verbal approval for the port.
If still issues with porting, you may also submit a ticket with Public Mobile representatives (CSA) for help; for issues with transfer/porting of phone numbers over to Public Mobile.
02-10-2023 02:23 PM
@JudyMac11 Yes, that's important to receive the transfer text and the old account also needs to be still active.
02-10-2023 02:21 PM
So to understand I have to put my old sim back in my phone?
02-10-2023 02:21 PM
@JudyMac11 Additional info on porting
When transferring (porting) your number to any new carrier it’s important to remember to leave the old providers SIM card in the phone until you receive the confirmation text from old carrier @that point you have 90 mins to reply YES to the confirmation text … also when going thru this process the new provider will want you old providers account number and will ask for IMEI number disregard this (IMEI) number as it has a tendency to just cos porting hiccups .. so if your ready to port to pm and already activated a SIM card you can go to your self serve serve profile tab and change /transfer (port) number this can also be done on activation but it’s advised to pick a temp number first then port
02-10-2023 02:19 PM
@JudyMac11 I'll private message the Telus porting # you can call and they will request your previous provider to resend the SMS transfer request but keep the old SIM in your phone and respond with a YES within the 90 minute window.
Please check your message inbox top right.
02-10-2023 02:19 PM
A critical part to porting is to receive a text from your old provider and you have to reply YES within 90 mins. If you are not receiving calls and text on your PM sim card and can only make outgoing calls, then you might have missed the step and hence porting was not completed
There is a number to call to talk to live support, they can re-trigger the process for you. I will message the number to you via the Community inbox. Check the envelope icon on top right. Call them and get it fixed
02-10-2023 02:19 PM
@JudyMac11 There a number to talk to live support to restart port process I’ll send private message
