01-10-2018 09:53 PM - edited 01-05-2022 03:54 AM
I cant send text messages but I can receive them and make and receive calls.
01-10-2018 10:50 PM
If the plan has text messaging, could the problem be with the app? Try using a different app.
01-10-2018 10:27 PM
Login to your self-serve account and confirm you have text added into your plan. If yes, try using other texting apps.
