4 weeks ago
It never connects. I have unlimited Canada/us/mexico and have enough data. So not sure what I can do
4 weeks ago
hi @hairbag1
yes, fixed as of 10/10, CK_PM post has an update.
4 weeks ago
has Public Mobile customer support chatbot process been repaired or do we still use dm customer support ?
4 weeks ago
hi @Jeaneid67
it is a common issue for many accounts for the past couple weeks if not month
try reboot phone and call again
if same, ask PM support agent to fix it on the system.
submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit ticket by direct message:
4 weeks ago - last edited 4 weeks ago
This has happened to a few others and Customer Support was able to fix.
added link…
