08-10-2021 06:02 PM - edited 01-06-2022 03:05 AM
I have Canada wide 100 calling. Which simon says is 100 outgoing minutes and then unlimited incoming minutes. In fact the plan worked like that for a few months now does not, and I am getting cut off from phone use long before I have 100 outgoing minutes. I tried to submit a moderator request, but I had to Login again, and I couldn't use my username and PW combination despite doing it again and again and having just logged into my account. I selected change your password, but I have not received the email for that despite trying again.
Please help.
Stacey
08-10-2021 09:16 PM - edited 08-10-2021 09:18 PM
@martymuskeg wrote:I have Canada wide 100 calling. Which simon says is 100 outgoing minutes and then unlimited incoming minutes. In fact the plan worked like that for a few months now does not, and I am getting cut off from phone use long before I have 100 outgoing minutes. I tried to submit a moderator request, but I had to Login again, and I couldn't use my username and PW combination despite doing it again and again and having just logged into my account. I selected change your password, but I have not received the email for that despite trying again.
Please help.
Stacey
Hello @martymuskeg
After you selected change you password, did you check your JUNK folder for any emails?
Is it possible you never registered for a Self Serve account? If not, you can do that here: https://selfserve.publicmobile.ca/self-registration/
Does the Plan Minutes show up on your Overview TAB in your SELF SERVE account?
IF not, than that usually means you used them all up.
Buy the $5 Canada-wide addon for 500 minutes - great buy!
If you previously did registered for a Self Serve account, then yes, only CSA representatives can get you back in, if the Forgot your password option is not working.
https://www.publicmobile.ca/en/bc/get-help/articles/contact-a-moderator
To contact the Public Mobile Customer Support Agent (CSA)_Team, there are two methods to reach them:
1 - Faster - Click the bubble comment circle on the bottom right-hand side of your screen,
or use this link to: Get Help With SIMon the Public Mobile chatbot
OR
2 – Slower - Use this link to:
Private Message to Public Mobile Customer Support Agents (CSA)
08-10-2021 06:10 PM
you Have To Submit a Ticket To Customer Support Agent by CS_Agent,
Here’s how to contact Customer Support Agent by CS_Agent,
Good Luck
08-10-2021 06:05 PM
i suggest you can try it for a different Browser
and do clear cache and cookies for any Browser,
and use a Browser from your computer,is better
use Browser microsoft edge or chrome latest version
and just make sure your Browser is up to date update
sometime is the Browser is not update is give a issue.
for microsoft edge how to update your browser visit Here
and Restart your computer, is will help a lot,
and if you use a home internet please do one thing take your power internet off for about
a 1 minute and put it back on,to refreshing your network,
you can Change Your Plan online,
When you’re changing your plan, you can choose to change immediately or at your next plan renewal date. To change your plan: sign in to Self-Serve, select ‘Change Plan’ on the Overview page, select the plan you want, and scroll to the bottom of the page.If you’re looking to apply a promotion to your plan, learn how you can do that here.
Changing your plan on the next plan renewal date
We recommend you choose this option because it allows you to use the services you have already paid for until your next plan renewal date. Here are some things you should know about this option:
Changing your plan immediately
You may choose to change your plan immediately if you have used all or most of your services, or if your account is suspended and you would like a different plan. Here are some things you should know about this option:
What will happen if my payment wasn’t completed?
In this scenario, your account could still move from suspend to active, re-starting your plan cycle and potentially only reactivating a portion or none of your services. If you find yourself in this situation, simply go to the “Payment” tab in Self-Serve, choose “One Time Payment”, and opt to pay the “Amount Due”. This will cover the new plan cost less any partial payment that was taken. After successful payment, your services should be fully reactivated. If your services aren’t restored,please start a conversation with our virtual assistant, SIMon, to submit a ticket to Customer Support Agent by CS_Agent, click here.
