06-06-2023 03:58 AM
Thanks for your assistance. I had around $30 of credit on my account that I would love to get back, really appreciate it.
06-06-2023 09:54 AM
this is exactly why one shouldn't leave too much $$ on their account. If they decide to go elsewhere, PM won't refund that balance.
If customer is migrating to Telus, I've heard that they may be some transfer of funds possible...but otherwise best to not have too much more than 1 X renewal in your Available Funds.
06-06-2023 08:57 AM
@JR74746 No refunds or proration even when changing subscriptions from what I see. As others have said, I think the only possible way is to contact CS_Agents
06-06-2023 07:22 AM
@JR74746 - how did you cancel your account? If you just opened an account with another provider, and your Public account has just been in nonpay, suspended status, then you can use that balance for a lowest cost plan for a cycle or 2 depending on the plan.
Only porting your Public Mobile number out to another provider automatically closes your account, access to My Account and loses any Available Balance you may have had (exception may be as @HALIMACS mentions above).
06-06-2023 07:05 AM
@JR74746 no refund as PM is prepaid provider. I don't think you will get a different answer even you ask Support
However, if you are porting into Koodo or Telus, since they are all one big family, Koodo or Telus could give you a one time credit instead, so ask them instead. But if you are going elsewhere, sorry, you might want to wait another month to use up your credit instead
06-06-2023 05:58 AM
The only time I have seen public mobile possibly willing to 'move' a credit upon account closing is if they are moving to Telus or Koodo, given they are all under the Telus umbrella of companies.
Otherwise, no, sorry.
06-06-2023 05:10 AM
06-06-2023 04:39 AM - edited 06-06-2023 04:40 AM
Unfortunately, PM is a prepaid service so there are no refund. Unlike postpaid service where it is prorated.
You can try your luck and contact a CS_Agent but I highly doubt that you will get a refund.
