05-29-2023 08:37 PM
I need to cancel my account immediately
how can I do this with no phone or security at all
05-29-2023 08:46 PM - edited 07-10-2023 02:46 PM
To "cancel" the plan, you can either port out your number to another provider and your account will be closed upon successful port out of the number
Or you can disable the toggle "Subscribed" to disable Pre-Authorized payment instead. Once it is disabled, PM will not be able to renew your account on your next renewal , your account will then be suspended on that day and 90 more days, it will be closed
To disable Pre-Authorized payments (Turn off Subscribed) , you can do it by one of the following:
05-29-2023 08:39 PM
@Suffolkboy Change credit card number or 611 if you know the PIN number
05-29-2023 08:38 PM
HI @Suffolkboy
still need to cancel your account?
quickest way is to port the number out, your account will be close
if not, login to My Account and disable Autopay , or use *611 to disable (4 digits PIN needed)
