10-01-2018 03:45 PM - edited 01-05-2022 01:59 AM
Hi,
I have a plan with 500 mb data per month. But i cannot use the internet at all. Does anyone know what’s wrong?
thanks a lot
Bill
10-01-2018 04:04 PM
@Bjiang18, check out this knowledge base for what to do after activation. It is very likely to be applicable to your case.
https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/How-to-Activate/ta-p/251824
10-01-2018 03:48 PM
@Bjiang18 wrote:Hi,
thanks a lot
Bill
You will probably need to check your APN settings. Here is a great site to setup your APN and instructions on how to do it. Find the APN Settings for Public Mobile here!
10-01-2018 03:47 PM
Either your data isn't enabled on your device, or your APN Settings need to be updated.
Please check the Knowledge Base for many useful tips!
