05-24-2018 03:39 PM - edited 01-05-2022 04:49 AM
I have an older LG flip phone which had a Rogers SIM but not activated for a few years. I checked and it seems compatible with PM. I inserted a PM SIM and it is asking to unlock the SIM/Phone. I called Rogers and got an unlock code but it keeps saying the unlock code is incorrect. I've never done this before so not sure if I'm going about it the right way! Any suggestion?
Thanks
05-25-2018 12:08 AM
@Regele wrote:When I put the Rogers SIM, it doesn't ask to unlock the phone; only when I put the PM SIM.
Unlock code is only requested when the SIM locked phone sees a SIM card that is not associated with the network to which it is lock. You should be able to ask Rogers for an unlock code for free. Use the Public Mobile SIM to apply the unlock code.
05-24-2018 04:44 PM
What model is the LG flip? You are correct that some older phones will work on Rogers but not PM, even when unlocked.
Can you try the PM SIM in another unlocked phone?
05-24-2018 04:22 PM
On the LG phone, after inserting the PM SIM, it says "SIM Card Invalid, network lock, Use ROGERS SIM only". It gives an option to Unlock. Maybe the PM website said the phone model was compatible but it is not!
05-24-2018 04:12 PM
05-24-2018 04:11 PM
I got the same code through their Chat and Phone support!
05-24-2018 03:48 PM - edited 05-24-2018 03:58 PM
Hi Regele!
I hope you are doing well. I am sorry to hear about that. I will try to help you with this matter!!
Here is the following step to do for unlocked your phone:
1 - Put your Rogers sim card in the phone
2- Once they asked you the SIM code put the unlocking code that Roger gave you.
3- Once it's complete you will have to turn off the phone, put your Public Mobile Sim card and when they ask for the code PIN put 1234
Be sure that you activated your Sim card too, then you should be able to use your public Mobile card Sim
Please let me know if it works !!
Have a great day,
Cheers,
Celsina
05-24-2018 03:45 PM
@Regele, i would re-check the numbers. If it still doesn't work, contact rogers again, and re-get the code. Perhaps they misread the numbers when giving it to you, or geting your IMEI number.
