Can’t transfer Phone
Cuty
Hi there!
 I did step by step as your request by reset network but my phone still not connected
can you tell me what to do
CSA_PM
Customer Support Agent
I sent you a private message — you can reply by clicking this link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
Cuty
My old service was active, but after relying with Yes to the Bell text prompt, my number is not on service
hairbag1
@Cuty
are you trying to port your old number in to Public Mobile ? Your old account must still be active.
slusagm
it's not a trasnfer issue but problem with account setup.  PM can help but you need to submit ticket
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
