02-13-2023
10:51 PM
02-14-2023
12:45 AM
Dunkman
Why can't I reset my password on everything but just keeps saying the same thing now it says I've exceeded the amount of tries
02-14-2023 07:29 AM
@Alycatstraz - try again, it should work on mobile. It took me a few times just now though.
Allow the email and password to autofill, then WAIT. Do not hit the Log In button. It will automatically log in itself.
02-14-2023 12:06 AM
The website is undergoing maintenance at midnight EST.
02-14-2023 12:05 AM
@Alycatstraz Self serve site if down for maintenance
02-13-2023 11:51 PM
@Alycatstraz Also site is undergoing maintenance at this time could be affecting being able to log in.
https://productioncommunity.publicmobile.ca/t5/Announcements/Scheduled-System-Maintenance-on-Feb-14/...
02-13-2023 11:45 PM
@Alycatstraz If your still having trouble get support to help you regain access to your account
Watch for reply top of page to the
Right ( envelope image )
02-13-2023 11:43 PM
@Alycatstraz Try signing in again incognito private mode mode there are cache isssue , or try another device or lap top
02-13-2023 11:35 PM
I can't sign into my account period even when I get the email verification code and put it in and create my new password it then gives me the same alert saying that my login info is incorrect. But why can I sign into my community?
02-13-2023 10:58 PM
Type everything in....don't use auto fill. Maybe you made an error like a comma instead of period in your email address. And use the advice provided above as well.
02-13-2023 10:53 PM - edited 02-13-2023 10:54 PM
Hi @Alycatstraz
close all browser and clear cache/ cookies/ open inPrivate mode,from computer. Login again, or trying reset password but if you know your password is right not reset,
02-13-2023 10:53 PM
@Alycatstraz No worry about the "exceeded the amount of tries". Just close the browser
But I suggest you to try Reset Password and login using Incognito mode and see if it works
If not, then Pm Support is your friend:
1. Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
