08-25-2022 01:41 PM
I have been having this problem on two devices now. I was on a one plus 5t phone, and couldn't send sms messages. I recently bought an iphone 11 pro and now I can only send imessages but still can’t send sms messages. I changed my apn number to the recommended one and have done everything a quick google search will recommend. If anyone can help I would greatly appreciate it.
08-26-2022 09:31 PM
08-26-2022 01:41 PM
Is there a way I can change that on my iphone, I can't seem to find SMSC in my settings
08-26-2022 01:40 PM
There is no prompt when I go to that section on my phone
08-26-2022 01:30 PM
HI @goalie1
For Carrier profile on iPhone:
you can manually update carrier settings by following these steps:
08-26-2022 01:27 PM
What do you mean by carrier profile settings?
08-26-2022 01:26 PM
There is a seperate messaging centre/SMSC phone number setting on devices that tells the phone how/where to send SMS message through.
08-26-2022 01:22 PM
What do you mean by message centre phone number- the only number I see is when I go to messages, send & receive, and the number thats attached to my plan comes up.
08-26-2022 01:19 PM
HI @goalie1 have you opened a ticket with PM CS agent yet? If not , please do so. I think we helped with all the quick trick we can already
08-26-2022 01:12 PM
They are both enabled, still cant send sms
08-26-2022 12:12 AM
ok. thanks. the issue in network!
08-25-2022 11:50 PM
@Timer wrote:turn off device take out SIM card and if you have other device treid to insert SIM.
- Reset Network Settings >> How to Reset Network Settings
- check APN settings >> How to Set APN
- Go to Settings and tap "Messages," then make sure "MMS Messaging" is turned on by swiping the button to the right.
- MMS Go to Settings-> Cellular-> then tap the switch to enable Cellular Data.
- Update iOS > Go to Settings > General > Software Update.
- and rebooting device.
There's no reason to make any changes to APN settings. The customer has already stated that MMS messages can be received. The APN settings for sending and receiving MMS messages are identical.
08-25-2022 07:25 PM
08-25-2022 02:17 PM
Did you register the phone to your Apple ID account? Did you turn on SMS and MMS in the iMessage app?
Also, settings, general, about and see if any updates occur.
08-25-2022 02:14 PM - edited 08-25-2022 02:14 PM
HI@goalie1 actually, are you on iPhone now? If so, you cannot do much with APN settings. You need to update your Carrier Profile settings, make sure you are on the latest one
If it still fails, you need to open ticket with PM CS Agent, I think it is a problem on their end instead of locally:
open a ticket with PM CS Agent at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
start by typing : Contact CS Agent
then Click "Contact Us"
then Click "Other"
finally Click "Click here to submit a ticket"
08-25-2022 02:11 PM
Check settings on your phone - what is Message Centre phone number.
Check restrictions setting for MMS.
08-25-2022 02:09 PM
Hi @goalie1 Since you can receive, I believe you have your Mobile Data enabled already
You can try to Reset Network setting once (but be aware that you have to rejoin your wifi network after)
If still fail, first Check your APN settings
https://www.publicmobile.ca/en/on/get-help/articles/set-up-data-on-an-android-phone
if that doesn't work try make a change to these fields:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
08-25-2022 01:53 PM
@goalie1 hi in your settings go to messages,make sure send as sms and mms are enabled
