Can’t receive texts
Roshan2
Just activated my public mobile plan and I can send outgoing texts but am not receiving any texts. Anyone know how to solve this issue? I’ve tried restarting and changing settings
@Roshan2 wrote:
Tried all that still not working
@Roshan2
Then you will need to submit ticket for CSA help.
https://www.publicmobile.ca/en/on/chatbot
Follow the prompts to submit ticket.
CSA may ask a few questions to verify account ownership and then should be able to help you. Response times can take a few hours.  Check your private message inbox (envelope in upper right corner of website).
Roshan2
@Roshan2 wrote:
I got a new number when I signed up and activated my sim , data works , incoming calls don’t work they fail
@Roshan2
So, not a porting issue then.  Likely an account provision problem.
A few basic trouble shooting advice:
You could try the SIM card in another working phone. This helps determine whether phone issue versus Pm service problem.
Did you try network reset of phone?
Toggle airplane mode on, then off
If PM service problem., you will need to contact customer service agent.
https://www.publicmobile.ca/en/ab/get-help
Chat with Simon the chat bot to submit ticket.
Roshan2
Dunkman
@Roshan2
Did you port your number over from another mobile company? If you did port, did you response yes to your original carrier's port request confirmation text?
What about incoming calls?
Does data work?
