Can't receive texts from Public mobile to set up account
kevinandj
Hi there,
Wondering if anyone has ideas around why I am not receiving a text, from my new PM number, in order to set up an account.  Receiving texts np from many other sources.  Tried asking a mod on here but after several emails back and forth simply verifying my account they were unable to help, and very unhelpful generally I might add.  In fact, the mod asked me to verify my account with a link that did send a text that worked.  I did have a PM account but PM will not let me access the account saying it's inactive if I try and login or saying it's disabled if I try forgot password.  Can't get to the screen to enter a (new ) email until I verify the number with a text.
Thanks in advance.
Kevin
7 REPLIES 7
@kevinandj wrote:
Hi there,
Thanks in advance.
Kevin
@kevinandj
I see your Community Account was created a while ago, maybe the phone you are using is on a phone that has Blocked Public Mobile communications.
You could also try the SIM in another phone to receive the text.
@kevinandj
As per @Anonymous inquiry....did you just order a sim card online or have you activated the sim card online after recieving it?
@kevinandj
You must have a new moderator. Give them the following info:
  1. Full name, province and postal code on your account.
  2. Phone #, email and pin#.
Sounds like your account didn't set up correctly they will have to do that for you.
 @kevinandj : The "account" you made for ordering the SIM has no relation to any other account here. Go figure. Is that what you're wondering?
kevinandj
Hi,
Thanks for getting back.  I did activate it online and that is true that i did use my email adress to simply order it online so an account should already exist.  When I try to log in though it does say the account is disabled so it does seem like a moderator needs to unlock it.  Trouble is after a few emails back and forth with a moderator they are still saying I need to start over with account creation.
popping
@kevinandj wrote:
Hi there,
Thanks in advance.
Kevin
You can provide your PIN number to verify your identify.
PM will send you a welcome email and text message about your PIN# after activation.
If you have not receive any message, your SIM card may not be activated yet.
If you activate online, your self-serve account already created.
If you activate in store, your need to create your self-serve account.
- There may a typo with your email address during activation.
- Call your new PM number from another phone.  If you phone rings, your SIM card is activated.  If you get a "number not assigned" message or someone else answer your call, your SIM card was not activated.
@kevinandj wrote:
Hi there,
Did you activate your account at the store?  If not, your self serve accoint would have been created.  Otherwise, you'll need to have the moderator help you.
