Can't reach out to customer support
liamster111
My number transfer "completed" when I signed up and I was using my old number for a few weeks through public mobile but my number was still registered with my previous provider so phone calls from that providers customers were sent to vm. I was going to contact support to see if that could be fixed but today I got a text that my number transfer failed weeks later and have been assigned a temporary number, just looking for a customer support agent to help me please as I no longer have an account with the previous provider so I can't complete the number transfer process
Please open a ticket using the chatbot.
If the ticketing system in the chatbot gives an error message, send a private message to CS_Agent.
@liamster111
did you reply yes to a text from your old provider to approve the port??
There is a number to call to talk to live support,  they can re-trigger the process for you.  I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) .  Check the envelope icon on top right.  Call them and get it fixed
@liamster111  Sounds like the port didn’t complete . I would start with porting team first will send  you the number private message . But to submit ticket you can use this direct link to support
send  a  private message   To CS_Agents
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
