Can't make calls or receive calls ,txt . No network in Brampton
Siddharth20
Phone not working what happened
2 REPLIES 2
hi @Siddharth20
did you login My Account and check if your account is active or suspended?
if it shows suspended, click Pay and Resume Services and make a manual payment
if it shows active, then reboot your phone and try Reset Network Settings.  Also, try the sim on another phone.
if same, report that to PM support agent, you can submit  ticket by direct message:
@Siddharth20
Check to see if there is an outage in your area. This could be the issues until repairs are done.
https://istheservicedowncanada.com/status/telus/map
