Can’t log in
viktordueck
My phone got stolen. Can’t receive sms or voice messages for authentication.
2 REPLIES 2
@viktordueck  Try hitting “didn’t get code” you should then have option to have code sent to email instead , if no dice get support to help you
send  a  private message   To CS_Agent
Dunkman
@viktordueck
Do you still have access to your email associated with PM account? If you do, then you can get 2FA email code sent instead of text or call.
Click on the "didn't get the code" link and then should be offered 2FA email option
