06-02-2025 04:46 PM
My phone was stolen. I bought a new phone and SIM card which I installed. When I went to my account and used eversafe saved information I realized that the email address was wrong. It was discontinued a couple of months ago but I forgot to change that in my account. Trying to login in it would send the confirmation code to my old email. Can you please help me to correct my problems? Thank you
06-02-2025 06:16 PM
Thank you for bringing this to our attention! The customer was already in a private conversation with one of our agents when the post was escalated. The agent will continue assisting them directly.
06-02-2025 05:47 PM
Thank you
06-02-2025 05:36 PM
I have escalated your issue to customer service agent. They should contact you via private messaging within the next 0.5-1 hour. Likely will need to answer some security questions to confirm the identity.
06-02-2025 04:50 PM
HI @BN105
email is the backup method to receive 2FA. Without the proper email, you will need to ask PM support agent to help. You can submit by direct message:
06-02-2025 04:50 PM
you have no choice but to ask PM to help with the change and email update
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
