02-16-2019 09:22 PM - edited 01-05-2022 03:23 AM
I orginally set up the phone plan at a kiosk in the mall, never registered for self-serve, or at least I don't think so. I am trying to cancel my plan because I lost my phone, but in order to do that I need to set up a self serve account and in order to set up a self serve account, I need my phone because a security code is sent to my phone, so I am in a catch 22. How to do I cancel the plan without a self serve account?
02-17-2019 12:37 PM
@Dunkman wrote:You can contact a moderator for help, but it can take 1-2 days for response.
Send a private message to moderator through the following link :
You might have set up a self service account earlier. Maybe try the reset password function also.
This is your best bet.
Just thought I would add you are likely to get a response by Monday and the Moderators would still like your account number and/or phone number in your private message.
Another thing I would like to add is if the kiosk set you up while asking for your email address you may use that to acquire/reset your password and access self serve again. If you have time to try today that is.
02-17-2019 07:55 AM
you need reach out to the moderator team for assistance. The moderator team can be reached via private message include in your phone number,account number and PIN code.
02-16-2019 10:09 PM
@worldlins, this will not work. The subscriber needs to contact the Moderator_Team, as they do not have access to a self serve account.
@worldlins wrote:Maybe you could buy a new SIM card by the counter and activate it with your number there.
02-16-2019 09:53 PM
02-16-2019 09:29 PM
