Can’t add my new bank card
Muhib
I have difficulty adding my new bank card to my account although I have my login information but when I login I can’t find any option to add my new bank  card
JRod
@Muhib
The Public Mobile site is having some issues at the moment. Check back in an hour or so. When you do check back you can use this link to take you directly to where you can manage your payment:
https://myaccount.publicmobile.ca/en/account/my-payment/manage-subscription
Muhib
I can’t access that is anyone here can talk to me in messenger so I can share screen
JRod
@Muhib
Can you access the payments tab? If you go to payment, then manage subscription, you’ll have the option to change the payment method.
Here is a direct link:
Muhib
When I login all I can see is the subscriptions plane I can’t find any other option
Does your bank card have either a Visa or Mastercard logo on it? Otherwise, it won't be usable.
HALIMACS
@Muhib
go under manage subscription and there you will find the option to update your payment card.
