10-26-2022 06:16 PM - last edited on 10-26-2022 08:28 PM by computergeek541
I just switched from android to iPhone, and now I cannot access my voicemail!
I tried clicking voicemail, holding/dialing 1, and calling my number and it just beeps and hangs up.
I have also tried calling my number from another phone and then dialing * and or # at the voicemail greeting, but it just hangs up after ringing a few times without any greeting.
I had voicemail before switching and now nothing, this is my business number and I need my voicemail. Help!
10-27-2022 03:05 AM
Self solution (and incorrect solution) removed
10-27-2022 02:39 AM
Good to hear. I'm confused how setting the basic APN would affect being able to use voicemail. APN is about data. ?? Oh well. You're on your way.
10-27-2022 01:57 AM
Updated my APN Settings and got my voicemail back.
10-27-2022 01:55 AM
Thank you for your reply to help. I was able to fix it by updating my APN settings and it started working 🙂
10-27-2022 01:53 AM
Hi, not sure why you are even replying to my help request. So you don't have the problem I do, and do not have any solutions? I don't understand why you even commented.
Thanks for stopping by anyway 🙂
10-26-2022 08:11 PM
@SAS7718 After you clicked the voicemail and listening the message you dial 1, then you can listen your voicemail and don't need calling your number. I don't understand why you need call your number for voicemail. I recently changed android phone to iPhone 8 Plus, I don't have the problem you have.
10-26-2022 06:22 PM
Try dialing this:
*5005*86*17785804001#
