Can’t access my account
afarrell
How do I change my email address
Firstly, @afarrell are you a current Public Mobile customer? Only someone with an activated SIM card and a plan has access to My Account/My Rewards.
If you are not a customer, you can activate a SIM card here: https://publicmobile.ca/en/bc/portal/activation
Then you will get set up with access to your My Account using your email and assigned password.
Or, if you ported your number out from public or have been in nonpay suspended status for over 90 days, this also closes your account with Public, and you have no access to My Account any longer. Is this your case?
pmbc
@afarrell You'll need to contact the online support agent to change your email address for your account.
You can contact an agent using the chatbot.  Type "agent" and click contact us to go through the wizard.
If for some reason they don't respond to the ticket, you can try to send an email directly to the CS Agent here.
Here is a KB article about contact the CS Agent.
Meow
Only agent can do that for you.
To Contact CSA-agent there are 2 methods:
Ticket has to be opened through chatbot - https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Having a ticket is preferred way to contact agent as they might respond faster then receiving personal mail.
If opening a ticket does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+) Here
Agent’s response is usually between 15 and 120 minutes with a ticket. Private messaging might take longer.
@afarrell   Only PM support can assist with email change for My Account
Please open ticket with them using Chatbot
1.  Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
