01-01-2023 12:06 PM
Have reset my password multiple time still can’t login to my account. How can I get access? Need to close this account, but want to port my number to new carrier.
01-01-2023 12:41 PM
If you still have the "Welcome to public mobile" e-mail you may have received on activation, the account number is the long number embedded in the "TO" field of the e-mail. It begins with a 1, followed by several zero's, then 6 or 7 digits.
That's the number your new provider will require for smooth porting there.
If you didn't have auto-pay setup on the PM account, no need to access the account at all.
You're good to go!!!
01-01-2023 12:24 PM
After resetting password wait 20 min and try again.
If if still does not work, contact agent to reset your accees.
01-01-2023 12:15 PM - edited 01-01-2023 12:16 PM
@JacobHoy is your account still active? you have not ported out your number yet, right?
If Reset Password does not work, open ticket with PM support using Chatbot and they will reset it for you
1. Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
Once the password is reset , use Incognito mode to try to login
Once you get the access back, you can get the account number from the Profile page there
https://selfserve.publicmobile.ca/en/account/my-profile
01-01-2023 12:13 PM
once you port your number it will automatically cancel your account .. also you will need to know your account number to port to a new carrier ….you can try to log back in incognito mode/ private mode there’s been cache issues
01-01-2023 12:12 PM
In order to port number I need my account number. How do I find that if I can’t login to my account?
01-01-2023 12:09 PM
Your account will close automatically, once you've successfully ported away from PM.
