10-04-2016 05:10 PM - edited 01-04-2022 03:36 PM
10-12-2016 08:05 AM
@Jiangjun1949 - you should make a new topic just for you and explain everything you experience; easier to see it (easier to overlook if you have it in someone elses topic)
10-11-2016 05:21 PM
@kkum 1. You cannot overpass your Data Limit. When it's finish it's finish. nobody will charge you more like other providers.
2.You can send a private message or Facebook message to Pm to tell you how much data you've got left.
3. This things happen very often since PM have some glitches while try to integrate the new technology from Telus to their subsiders.
4. I made a topic which cause this kind of issue. Go and look for "Changing Plan Issue"
Usually cause of this issue is suddenly chaning of plan.
Also Moderators in this kind of error they will write a ticket to technician which usually take care of this kind of error.
5. Let's be honest. I never use PM website to acces my Self serve. I only come to acces forum.
I know on my self serve everything is set properly so why do i wanna go there 😛
10-11-2016 03:32 PM
10-06-2016 07:38 PM
10-04-2016 05:14 PM
Hi @kkum,
Could you send me your phone number through a private message? I will look into this! 🙂
