07-05-2021 03:17 PM - edited 01-06-2022 02:58 AM
i just ported into PM on 30th June.
outbound calls are working for me with the ported number
inbound calls are not working
text messages are not working as well.
how do i get this sorted ?
07-05-2021 03:43 PM
can you do try reseat the SIM card
1.power off your device
2.take out the SIM card,
3.wipe it clean SIM card,
4.put it back and power on,
5.toggling airplane mode off/on,
it happened sometime you know, A normal reboot without reset, didn't work. At least try it,
only work after reseating the SIM card.
can you try it selecting the network to "3G ONLY"
for iPhone visit HERE
or HERE
for android visit HERE ,
what is mean for Rebooting the phone means to turn off your phone and turn it back on.
if you still not working you have to Submit a ticket to customer service by Moderator Team,
Only one way to solve your issue , explanation to customer service by Moderator Team
and the are nice service Team the will help you 100%.
Here’s how to contact customer service by Moderator Team,
Good Luck
07-05-2021 03:19 PM - edited 07-05-2021 03:22 PM
@prembasak1 for porting , an important step is one that you receive a text from your old provider and you need to reply YES to allow the porting to happen. Did you receive that text and did you reply YES?
It sounds like you missed it and hence porting is not completed. Since porting is not done, it's normal that you are not receiving incoming calls at the moment.
I will send you a phone number at your Community Inbox (envelope icon on top right) , that is for the porting team, they will confirm the porting status and advise.
(** unless you are porting from landline, which you won't receive the SMS , but porting from landline take as many as 5 business days)
