07-19-2022 02:14 PM
Can someone correct an issue on total data or explain how I get these 2 different amounts
Have 1 gig / 1024mb plan
Shows I have used all data
Barely turn on data
Usage history shows less that 100mb
Images attachable?
07-19-2022 02:43 PM - edited 07-19-2022 02:44 PM
@dust2dust maybe they fixed, it .. so, you can go all the way 90 days with a filter without going through ALL page after page first with ALL type?
For me when I tested, it was only showing 2 weeks or 3 with the filter (if I don't use all to go through all pages ahead).. .But if i use ALL to go through all pages to 90 days, then I can use filter with different call type for 90 days
07-19-2022 02:40 PM
@softech- I just tried the filtering and it seemed to work fine. 30 days, Data Type. 2 pages of info. (low usage user)
07-19-2022 02:31 PM
07-19-2022 02:27 PM
This is exactly why i am posting - need data and its a security issue - don't feel i should have to pay for more data when there is a mathematics issue in PM's back end
07-19-2022 02:27 PM
@PM-GG And if you are using Android, try to check your Mobile Data page on your device, but remember to change your cycle start date.
Mobile data page will show you something similar to this:
07-19-2022 02:25 PM
Nope. That looks all wrong. As though the data didn't reset on the 21st. But you're a couple days away now to your next renewal...see what happens in the morning of the 22nd. Look at this same screen then. Unless of course you need more than 10MB now.
07-19-2022 02:25 PM - edited 07-19-2022 02:28 PM
@PM-GG before you filter your data in Usage log, try to use the ALL type to go thought all pages till you see Jun 21.
The Usage page does not work well at the moment (aka. bugs :)) You have to go till a particular day with ALL type before the filter will work till that day
Therefore, if you need entries for all data from Jun 21, make sure you don't filter anything, use ALL to go until you see entries on Jun 21, then you can filter by Data
07-19-2022 02:25 PM
go to your device apps turn off background.
07-19-2022 02:22 PM
Just posted images and hoping a Mathematics Genius is among people here 🙂
07-19-2022 02:19 PM
Figured out how to attach images of account info for anyone who is an expert in Mathematics!
07-19-2022 02:19 PM
@PM-GG hi what you see on the main page of your self serve account is the most accurate go by what you see there
