Can i use esim in japan
Fokion
hairbag1
@Fokion
ever heard of WhatsApp ? If you download the free WhatsApp, you'll be able to call family / friends who also have WhatsApp..uses local wifi or your separately purchased data. Convince your family / friends at home to get the app and you can stay in contact with 'em while you're in Japan...for free.
NDesai
@Fokion No, you can't. Check out https://esimdb.com/ to find some eSIM options. You can transfer your calls to a fongo or another similar voip app before leaving.
sorry @Fokion , no, PM does not have roaming service in Japan.  But you can buy travel eSIM instead. One popular one is Airalo
hairbag1
@Fokion
Public Mobile has no service options in Japan or anywhere else outside of Canada / US / Mexico. You need a local sim to get service in Japan..try Japan Wireless or Sakura Mobile. Depends on your cellphone if you can use esim or hard sim.
Chalupa_Batman
Hello @Fokion
Sadly no. PM only works in Canada US and Mexico.
But you can look here for an eSIM to use in Japan.
https://www.airalo.com/japan-esim
