05-16-2022 05:27 PM
Can I renew a plan with no data left with the same plan and use change now? I did that it acted ok but it still has not renewed and I would like to avoid spending the whole $140 now sitting in my account? Thanks
05-16-2022 06:04 PM
@myhandyman wrote:Did not ask about that just want some data.
Your original post said “Can I renew a plan with no data left with the same plan and use change now?”
If you are out of data and need some right now you have 2 options:
1. Buy a data add-on
2. Renew current plan or get a new plan.
05-16-2022 06:01 PM
You could buy the data add-ons. You could change to a different plan. You can ask the support people to do an early renew of your existing plan. The last 2 would require full plan payment up front.
05-16-2022 05:58 PM
05-16-2022 05:33 PM - edited 05-16-2022 05:34 PM
As a fyi, by changing the plan immediately you will not receive any credit (money) for the unused time of your current plan.
05-16-2022 05:29 PM - edited 05-16-2022 06:09 PM
@myhandyman wrote:Can I renew a plan with no data left with the same plan and use change now? I did that it acted ok but it still has not renewed and I would like to avoid spending the whole $140 now sitting in my account? Thanks
@myhandyman You cannot use Change Plan to change to the same plan you have now. You must choose a different plan if you want to Change Plan
If you want to renew early with the same plan, the only way to do is to open a ticket with PM Support and they will renew it for you:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
