Calls keep on dropping
ShahedJ
Hi,
I have a friend in the states who I call and it is constantly dropping. I need help!!!
thanks, S
1 REPLY 1
hairbag1
@ShahedJ
could be the dropped calls are a prob on his end if everything else seems to be working on your end. If you call someone locally or long distance in Canada...do the calls drop as well ?
