04-26-2022 08:28 PM
All of my calls go directly to voicemail and i don’t have my phone on do not disturb or anything like that.
04-26-2022 11:13 PM
Yeah it may be just re-seating your sim. Did you drop your phone recently?
04-26-2022 08:35 PM
Try restarting your phone.
Are you certain your PM account is Active.
04-26-2022 08:34 PM - edited 04-26-2022 08:40 PM
Try rebooting your phone, resetting network settings or reinstalling SIM card in your phone.
04-26-2022 08:34 PM - edited 04-26-2022 08:34 PM
Try your SIM card into another compatible phone for a few days to see if the issues are the same...this could rule out a device issue/setting.
You can also try to manually select the 3G / WCDMA ONLY network in your Mobile Connections area in your settings (temporarily) and see if that helps.
edit, first try restarting your phone...sometimes the fix is as easy as that.
