05-01-2025
05:17 AM
05-01-2025
08:09 AM
computergeek541
05-01-2025 08:09 AM
hi @John278
if you login My Account , go to Subscription & Add-on page, what plan do you currently have?
you talked about Agent told you, so, did you make the plan change with agent? or the agent already helping you with the problem you have?
and was it related with the issue you had in early April? If so, make sure you screenshot what the agent told you back then when you talk to agent this time
05-01-2025 07:23 AM
@John278 Just to clarify, are you trying to change subscription by cancelling the existing one each time? Just wondering based on what you said in a previous thread
05-01-2025 06:37 AM
Sign out of your account and back in using secret mode or clear cache to see if the plan will update to show the one you want.
If its still shows the $27, go back to the agent and ask them. You spoke with them already so reply back to that same message and ask them about it.
In the Community we are just customers and cannot assist you with changing plans.
05-01-2025 06:36 AM
@John278 Do you mean this plan 3GB for $22 4G plan it’s plus tax should be about $25
I don’t see $20 plan with 3GB of data
